Do you think the HHR could handle towing a 4X8 U-haul Enclosed Trailer?
I would use the I gear when towing. When I towed a trailer from NY to Florida in a Buick 3800SC, the owner's manual did not recommend letting the car to go into lock up as it would put too much stress on the transmission. I left the transmission in 3rd gear all the way. MPG was crappy @ 16 mpg, mostly because of air drag with that big box behind the car.
More HP at higher rpms.
I had some friends tow a car with a trail blazer just leaving their car in D and the tranny failed.
The towing capacity is not only for the unibody structure but also the capacity for the transmission to handle the additional load.
I pulled upwards of 1500-1700 with mine (1LT w/2.2L) a couple years back with a similar U-Haul trailer. My recommendation to you would be to invest in a good external transmission cooler. I had a tranny shop install one on my car for approx. $200, it mounts to the front of the radiator and takes the place of the stock cooler in the rad, but does not hamper radiator function, and makes the towing job a lot less strenuous on the tranny (the biggest danger when you tow anything is the transmission overheating, which can lead to slippage and other damage).
I would not do it simply because the brakes are pretty stressed with what fits inside an HHR.
i drove from Detroit to Birmingham Alabama and back with 700lbs of tools in my panel. Going through the maountains was interesting.
Never towed with an HHR, but I have been towing RV's for over 20 years. When I towed with relatively smaller vehicles (Chevy Astro or Chevy S10 Blazer) and relatively large travel trailers (GVW 3500-5000lbs) I typically and almost always towed in 3rd gear. This prevented the trans from hunting back and forth between higher gear ratios.
If this happens with the HHR in 4th, maybe it should be dropped back (unless there is something different these days; I recall an "Idiot" gear mentioned by some automatic owners on the site).
But I still would not exceed the 1,000 lbs capacity for towing. Heaviest I've every hauled on mine is my 4x6 tilt trailer with my old 38" Murray riding mower on it when I sold it.
