Ecm needs replaced
Ecm needs replaced updated with new info
2011 2.2 95000 or so miles gauges quit working mechanic diagnosed bad ecm can't find one at the salvage yards I was looking on ebay at flash masters anyone had any dealings with them ?
These are also a possibility
https://dashboardinstrumentcluster.c...ard-cluster-2/
I will have to check back with the mechanic for more information he is a friend of my wife he called and told her the ecm was bad all the fuses including the ones inside the car checked good battery was load tested good when I find out more I'll let you know Thanks for the help.
My general rule of thumb is any mechanic that thinks "replace the computer" is a waste of time and money. Especially with no evidence.
Who tightened the bolts in the fuse box? How tight? Did all of the tabs click in to their slots? Did anyone check all of the connectors and pins in them?
h'
h'
