factory fogs on an LS?
ive read all the how-to threads on factory fogs, and im going to buy a set for my 2010 LS, but i've also read the BCM on LS's can not be re programmed to control the fogs. does this mean i cannot use the factory fogs switch? do i just need to get the factory fogs, the 2 male bulb connectors, some wire, and an after market switch?
i found factory fogs for 20 a piece! i have my HID's to install in them so i dont even need the stock bulb connector now that i think about it.
As long as you have the lights, you should be able to wire them to a separate switch and then to the fuse box. Integrating with the factory switch and flashing the computer may not be possible, at least no one here has figured it out yet.
I put the factory fogs and switch on my 09 ls. You will have to tell the BCM that it has fog lights using a tech II. I did mine last summer and it has worked great since then, no problems. It looks like the car came with the fogs, it functions just like an HHR that had them installed from the factory.
Good to know it can be done with a reflash, probably a dealer charge as they have the tool and the flash settings. I know my dealer wouldnt do it, they require a corresponding VIN just to order parts.
I have my own tech II, but I did not reflash, just go into BCM and turn on fog lamp option. It has to know it has fogs. I did the same thing on my brother in laws G5. They bought it thinking it had cruise but it didn't so I got him a steering wheel with the buttons on it then I took techII and went in and turned on the option for cruise.
