Fender Bender & now stalling..
Old Oct 9, 2024 | 07:18 AM
With the amount of dirt and crud inside that throttle body, I’ll bet the air cleaner elbow hasn’t been connected properly to the TB. … For a good while.
Old Oct 9, 2024 | 01:32 PM
greg8453's Avatar
No scan tool?
Old Oct 12, 2024 | 09:45 PM
PulpFriction's Avatar
Betcha the throttle body got damaged.
Old Oct 14, 2024 | 08:23 AM
WoodysMobile's Avatar
TBI definitely needs cleaning. Basics; inspection of vacuum lines, hose and electrical connections, good grounds, battery full cca
and of course the famous fuse box tight!
Have a good week everybody
Old Oct 14, 2024 | 07:51 PM
Bleehobbs's Avatar
Thanks guys I have thought throttle body too.
I believe the brake pedal could be due to the main hose under throttle body I didn’t get a chance to look much. Currently doing 2 jobs.
One question is though why does the problem go away when I unplug the MAF? I unplug MAF & car revs up to 3k rpm & idles there, if I leave the car running for 3 minutes with MAF unplugged think it will idle down? I was afraid & turned it off after doing so. I suppose with it idling at 3k than it’s outside of its 900 RPM idle issue and is just working correctly due to idle so high.
My dad drove it home for me so I would think if it just had to relearn the TB than it would had done so during his drive home, so guess it is probably toast. The AC line did hit the TB motor & sensor so perhaps that hard hit locked the motor on TB.
Old Oct 15, 2024 | 07:12 AM
Easy enough to replace the throttle body.
Old Oct 21, 2024 | 04:06 PM
Bleehobbs's Avatar
Has anyone had any luck with GM buying back their HHR after an accident?
I say this due to the brakes not working & air bag not deploying. They admitted in a message that the airbag connection can become corroded & lose connection. They advised about a satisfaction program & fixing this however they haven’t notified anyone or announced it? At least not for my VIN. I noticed the point of impact was directly by the airbag sensor & they still failed to deploy. They want to come out and pull data from the car.
Old Oct 21, 2024 | 05:19 PM
I’m in Canada and haven’t had my HHR involved in a front end collision. But if you pass then you’ll never know! It’s worth a shot, they might surprise you.
Old Oct 21, 2024 | 06:59 PM
Just based on your pictures the impact doesn’t appear to be hard enough to deploy the SRS system. (Airbags)
You should be thankful they didn’t deploy. It’ gets a little pricey when you have to replace airbags, SRS crash modules and other stuff related to air bag deployment. Added on to body damage it adds up.
Not sure what you mean by your brakes not working. That’s not a known HHR problem.
SafetyDave
Sep 13, 2024 09:32 AM
Engineer in training
Sep 23, 2023 09:13 PM
desertrat
Jul 29, 2021 07:21 PM
anth3388
Dec 10, 2015 12:39 PM
tarchie
Aug 11, 2015 04:34 AM
