Finding things...
I have an 07, 2.2, LT, Auto tranny - where is the dip stick for the tranny located? And how do I remove the air cleaner cover to look at the engine air filter?
I like to keep the two rear / middle seats tilted down, to open the entire rear section up - what have people done to that open rear area to keep things from sliding all over? I thought of covering it with outdoor carpet... any other better ideas? thanks - kip OK, I found the thread about changing the air filter - what a great help - thanks much... But where is the dip stick for the tranny?????? |
there isn't one
No dipstick, treat the trans as a sealed assembly until you reach the recommended service interval in your manual. It takes a while getting used to not being able to check the fluid level in the trans, but unless you have a puddle of fluid in the driveway, forget about it until you reach 100,000 miles.
1 Attachment(s)
As 843 said you don't need to check it unless there is a problem. but here is a pic. also if you type in checking air filter in the search tab at the top you will find a how to on the air filter.
Originally Posted by kby
(Post 563056)
I like to keep the two rear / middle seats tilted down, to open the entire rear section up - what have people done to that open rear area to keep things from sliding all over? I thought of covering it with outdoor carpet... any other better ideas? thanks - kip |
Thanks for the info on the tranny... who would have ever thought you'd not check the fluid level??? Oh well...
What type of rubber matting did you use, and if I can ask, where did you find it? I have thought about indoor carpeting, but things will still slide around. Thanks - kip |
Bungee cords
i put my stuff in plastic tubs some times and tie it down with bungee cords |
