Fobs/ keyless entry...
Where are threads/posts about keyless entry and Fobs. I got one key....one Fob for the new to me 2011 HHR LT, 2.2.
I understand the car has to be linked to Fobs via scan tool or locksmith programmer. The Fob i have will lock the car....but will not unlock it....panic button works......i dont think the remote start function is working or, im not doing it right
TPMS....also got left rear tire pressure showing up....guessing sensor in that tire is bad or dead.
Im new here and not to good at searching out what im looking for
Buttons that don't work could be as simple as dirty contacts or worn out rubber pad... The pads are like $5 each on eBay.
i took it apart...cleaned with alcohol...key pad appeared ok...new fob battery. Kind of weird cause when first got the car couple months ago...no lock or unlock. Panic button only. May need to have car battery tested. Maybe freaking the computer out...lol
Did you try jumping the fob contacts? It is not always just dirt. Please believe us we have been around and around this.
Like this, there are others:
https://www.ebay.com/itm/11458934893...wAAOSw~65cXacx
Adding foil to the pads is hit or miss, especially with the replacement rubber being so affordable.
Ok, thanks. Ill try it when get a chance. The car is new to me and im on a big learning curve. Good news is...the chain, guides and water pump is done deal. Just cranked it up today. Running good. Having ti do what i can when time and money permits
