Found Problem for all HHR's (possibly)
Here is the second one. There is a 3rd but it only applies to 08 and 09 rubbing around number one fuel injector.
#PIC4125B: Reduced Power Message Or Long Crank No Start On The First Key Crank - keywords 2.2 2.2L 2.4 2.4L battery cooling crankshaft dead DTC drain draw engine extended fan hard harness key lamp L61 LE5 light - (Nov 17, 2008)
Subject: Reduced Power Message or Long Crank, No Start On The First Key Crank
Models: 2006 - 2007 Chevrolet HHR
This PI was superseded to combine information from AIC3193 due to both concerns coming from same harness issue. Please discard PIC4125A.
The following diagnosis might be helpful if the vehicle exhibits the symptom(s) described in this PI.
Condition/Concern:
A customer may bring the vehicle in with a Reduce Engine Power message on the DIC. Any of the following codes may set:
P2120: Accelerator Pedal Position (APP) Sensor 1 Circuit
P2122: Accelerator Pedal Position (APP) Sensor 1 Circuit Low Voltage
P2123: Accelerator Pedal Position (APP) Sensor 1 Circuit High Voltage
P2125: Accelerator Pedal Position (APP) Sensor 2 Circuit
P2127: Accelerator Pedal Position (APP) Sensor 2 Circuit Low Voltage
P2128: Accelerator Pedal Position (APP) Sensor 2 Circuit High Voltage
P2138: Accelerator Pedal Position (APP) Sensor 1-2 Correlation
In addition, on vehicles with the 2.4L LE5 Engine (VIN Code P) only, the following codes could also occur:
P0651: 5 Volts Reference 2 Circuit
C0561: System Disabled Information Stored
P0326: Knock Sensor (KS) Performance
P2135: Throttle Position (TP) Sensor 1-2 Correlation
P0335: Crankshaft Position (CKP) Sensor Circuit)
It has also been reported that the cooling fans may run constantly due to this condition.
Recommendation/Instructions:
It has been identified that the engine harness may contact the purge solenoid bracket, causing harness damage and exposing the wires.
Inspect the harness and repair any necessary wires and secure the harness away from the bracket to prevent harness from grounding on the bracket.
Condition/Concern:
black Tara
2.0L Performance Tech
62
Jul 28, 2015 07:38 PM
polygurl2003
Feb 20, 2014 10:31 PM
