Chevy HHR Network
-   General HHR (https://www.chevyhhr.net/forums/general-hhr-4/)
-   -   Front Light with foglight question (https://www.chevyhhr.net/forums/general-hhr-4/front-light-foglight-question-36654/)
Silver11 Jul 21, 2011 01:09 PM
Is there any way to have all 4 front lights on when using High Beams? Also if so is there anyway to keep the fog lights on during the use of High Beams? So the ideal answer would be 4 light for high beams + Fogs if turned on.
Thanks :skull1::skull1::skull1:
Greybeard999 Jul 21, 2011 01:24 PM
Many state laws don't allow for that, that's why they are setup the way they are...... (fogs go out with high beams) Even if your state doesn't have it on the books (yet) you could get popped one state away.
LawDog88 Jul 21, 2011 01:25 PM
hi?lo beams are one bulb=blow out quick if you did that. and if you want fogs on with highs, my suggestion would be re-wiring fog lights to either a different switch, or the same one, bypassing, the high beam cut off. essentially just make it a pos/neg hook up to either stock or aftermarket switch.
Hope this helps.
solman98 Jul 21, 2011 02:14 PM
YOur not going to get both elements of the H13 bulb to burn at the same time. Extremely short life would be the result if you could.
I wired my fogs myself and can run the fogs with the high beams. On those twisty county roads I drive down leaving my house, very helpful. As far as legality, haven't heard that one before. If you are meeting a car head on, you shouldn't have your high's on anyway (that will get you a ticket in some areas). Some states have a law stating no more than 4 lights on at any given time on public roads.
Silver11 Jul 21, 2011 05:17 PM
ok so the old days of 4 headlights are gone... ok. Any quick way for the factory fogs to work with highbeams?
Thanks
nacademus Jul 22, 2011 10:03 AM
Trigger the fog lamps off of a relay with its signal voltage coming from the marker lamp. Always on when parking lights are on and either headlamp.
