Gas tank leaking at rollover valve
Is there a replacement for the rollover valve instead of replacing the fuel tank?
Send a PM to hellshotrod, David will know that one. |
I thought that was in the filler neck, not the tank.
http://www.gastankrenu.net/search-by...tank-fill-neck Are you asking because it is hard to fill the tank? Probably not the solution. |
