Good jacking points
Old Oct 25, 2007 | 07:16 AM
GCarp's Avatar
Originally Posted by jdmcomp
Jack up one rear side and put it on a stand. Remove tire. Jack up same side front wheel and remove replacing with tire from back. Jack up other back tire replacing it with front just removed. Jack up remaining front and put on tire just removed. Put the tire from the front on back and take off stand. One stand, one jack is all you need. Crossed the fronts to back and backs straight up to front. Simple.
If you have directional tires then do not cross just swap backs to front. This will require two stands and a jack. Really cannot imagine directionals on this car though. Waste of money.
Beat me to it.
Old Oct 25, 2007 | 09:12 AM
Black Rose's Avatar
Just one issue with this. The rotation order is incorrect (check the owners manual).
The fronts go straight to the back. The back tires criss-cross to the front.
RR goes to LF, LR goes to RF, old RF goes to RR, old LF goes to LR.
Old Oct 25, 2007 | 11:26 AM
GCarp's Avatar
Can still be done with one jack stand and starting with the rear.
Jack up LR put jack stand under. move LR to RF. Take old RF move to RR. Take old RR move to LF. Move old LF to LR. Remove jack stand. Done.
RBodeman
Jul 11, 2014 03:35 PM
vettman
May 30, 2010 12:18 AM
fantomfreke
Sep 15, 2009 08:25 AM
pitbull76
Mar 14, 2009 11:31 PM
GER42
Maintenance and Upkeep
Oct 24, 2007 09:47 PM
