Have the dreaded P0121 code.
The throttle body connections can be simply dirty and corrosion has set in. Check the connection for loose or bent pins. Clean and dielectric grease the connections.
Do not move the butterfly plate manually, clean it with CRC throttle body cleaner.
https://www.obd-codes.com/p0121
I have cleared the code a number of times and it comes back. Something odd today, started out this morning no check engine light, stopped at the drug store came out started the car engine light on, went to Walmart came out no light. Didn't come on after that.
Just a update on what's going on with my check engine light. After disconnecting my battery on number of times the light would go out for maybe three or four days. I then unhook the battery and unplugged every electrical connection under the hood that I could access. I cleaned all connections use Dielectric grease plugged everything back in reconnected the battery and now the check engine light will stay off for about a month at a time. Again I will unhook the battery the light goes out I can get a another month with no check engine light. I'm not sure what to try next.
