Hazard lights stay on!
Hi. I took apart the radio panel to check connection. Unhooked the hazard, the traction, the dimmer and radio connections. Turned out to be speakers were bad. I put all back and hazard lights stay on. Anyone had this prob
Only people that hooked the switches and lights back up wrong.
You probably made the misteak of thinking the hazard light signal sensor is a switch. Turns out if you reverse the connector it sends a constant signal to the BCM. Or, just reversed the switches.
The hazard and the traction control have the same connector. The same thing happened to me a few months ago. When you switch the connectors, turn the car on to verify before putting the waterfall back on, it'll save time and possible damage by taking the panel off again if you need to.
irisride
Nov 8, 2012 03:59 PM
