Chevy HHR Network
-   General HHR (https://www.chevyhhr.net/forums/general-hhr-4/)
-   -   Hazard lights stay on! (https://www.chevyhhr.net/forums/general-hhr-4/hazard-lights-stay-59364/)
Ilovechevys Sep 9, 2017 02:31 PM
Hi. I took apart the radio panel to check connection. Unhooked the hazard, the traction, the dimmer and radio connections. Turned out to be speakers were bad. I put all back and hazard lights stay on. Anyone had this prob
donbrew Sep 9, 2017 03:36 PM
Only people that hooked the switches and lights back up wrong.
You probably made the misteak of thinking the hazard light signal sensor is a switch. Turns out if you reverse the connector it sends a constant signal to the BCM. Or, just reversed the switches.
Oldblue Sep 9, 2017 03:47 PM
Check the connections, something is mixed up
SuKi Sep 10, 2017 01:38 AM
The hazard and the traction control have the same connector. The same thing happened to me a few months ago. When you switch the connectors, turn the car on to verify before putting the waterfall back on, it'll save time and possible damage by taking the panel off again if you need to.
