HHR LS Swap Rat Rod
#301
Thanks for looking out Cat. Its one of those optical illusions I believe. Right there at the end of the cable where it attaches to the carb there is a slight dent in the cable that makes it look like its loose. The throttle linkage doesnt move at all without pulling the tv cable. When the carb is at wide open throttle, the cable is pulled all the way out. And when the carb is at idle, there i no tension on the cable. This is correct right?
#302
You adjust the TV cable at the carb
Art Carr's 700r4 tv cable adjustment guide from CPTtransmission.com
#303
Buying the correct throttle cable bracket for this carb will greatly improve the adjustment also.
#305
Got the carpet and most of the interior back together this afternoon. Seats are bolted back in place. Cut my carpet off where my steel floor is gonna be. Took boxes will be mounted where the back seat would be. Very back in gonna have my welder and accessories on a slide that will pull out about 18".
#306
Look at the picture he has and you will see, compared to what I show, is in the wrong starting point for the cable.
#307
I did a lot of research into the tv cable. Thank you all for the information. As y'all suspected, it was put of adjustment. I used a valve cover tab to make a bracket to correct my angle and give me complete pull. Thanks again for the help!!
Guages are next on agenda for this afternoon. Wish me luck.
#310
Got the guages mounted where I want them. Was a nightmare getting my speedometer cable into a useable position, but it's there. Gonna mount my tach on the outside of the guage hump, to the bottom left. Wiring them all up is gonna be a blast
