HHR ride
Old Oct 15, 2014 | 01:51 PM
nanatthewheel's Avatar
HHR ride
I have been riding in my HHR 08 since 08 and at first i liked it then it started to feel like its ride was getting stiffer. So i was curious do i have to run those high performance tires is it at all possible to put some largers tires with some meat on them. If this improves the ride i could consider keeping it. great gas mileage approx 34 mpg loven that.
Old Oct 15, 2014 | 02:14 PM
Welcome to the site! What model do you have LS/LT or SS and what size rims are you running 16,17,18 ? what tire size do you have now? all these factor into the sidewall of the tire which helps with the ride the max height you can go is 26.2 inches, so a 215/55R16 has more side wall to absorb those bumps. use the search window to look up tire size chart
Old Oct 15, 2014 | 03:19 PM
JAN67's Avatar
Following this...
Old Oct 15, 2014 | 04:01 PM
Laco's Avatar
Took my 07 HHR in for a front end alignment, and was told both front struts were leaking, as well as both rear shocks. Replaced all of them, and the ride, though certainly not luxurious was definitely improved. Overall control also improved.
Old Oct 16, 2014 | 01:16 AM
dr_fosg8's Avatar
If you have the 17 in wheel you can go with a 225 50 17. Gives you about the most sidewall you can get with the 17 in rim.
Old Oct 17, 2014 | 04:44 AM
Ron S's Avatar
Welcome to the forum
Old Oct 17, 2014 | 01:42 PM
Knightrider03m's Avatar
I always found the HHR is be on the hard side when it comes to the ride. I pinpoint the ride being hard due to the 17 inch wheels not really allowing for a good sidewall size. However, I don't know if HHRs with 16 inch wheels have the same problem.
Old Oct 22, 2014 | 03:38 PM
pg318's Avatar
I've always thought the ride on my factory 16"s pretty good - certainly in comparison to the 225/40/18 summer tires I have on my other set of wheels - which have suffered numerous dings from potholes...
BigRedGoat
Apr 22, 2011 11:20 AM
heyjoe
Feb 25, 2011 08:43 PM
rmunson
Sep 16, 2009 10:14 PM
trfindley
Jun 14, 2009 07:43 AM
bad03xtreme
Apr 1, 2009 08:15 AM
