HHR setup as a “Toad”
Has anyone set up their HHR as a “Toad” towed behind a motorhome.
What base plate did you use? Did you have to trim the fascia for the brackets? Did you wire the lights with diodes and how did you route the wires to the tail lights? |
BOB & PAT,
This has already been discussed in other threads. Here are some links to help you out. NOTE:You can't tow a manual transmission HHR; ONLY Automatic's https://www.chevyhhr.net/forums/show...ghlight=towing https://www.chevyhhr.net/forums/show...ghlight=towing |
Thank you Kenny for the links.
Bob |
