Need help with Intermediate Steering shaft
Old 10-07-2017, 02:56 PM
serch826's Avatar
Exclamation Need help with Intermediate Steering shaft
Hello, I replaced the intermediate steering shaft but forgot to check the position of the shaft join in steering column and now there is a very small non centered steering wheel.
Can anyone here take a picture of the intermediate steering shaft in straight position, to see the rigth position in the steering column under the steering wheel?
I apologize for my stupidity and would be very grateful if you can help me with this and post here the picture.
Once again thank you for your help.
serch826 is offline
Old 10-07-2017, 04:41 PM
You just have to separate the shaft and yoke and centre the steering wheel, it might take a few tries!
Oldblue is offline
Old 10-07-2017, 04:58 PM
serch826's Avatar
Thanks for your time to answer, I've did some tries but steei have a very small difference.
serch826 is offline
Old 10-07-2017, 05:31 PM
One tooth can move it to far, then you’ll need a front end alignment to centre the steering wheel, or like me live with it!
Oldblue is offline
Old 10-07-2017, 08:30 PM
Technical Moderator
Be careful not to break the clockspring.
donbrew is offline
Old 10-22-2017, 02:35 PM
serch826's Avatar
Thumbs up Solved
Finally, I could fix this, watched and bought an original intermediate shaft and swap the cheap copy that I had bought, which I strongly not recommend, it was of poor quality.
All right put all the mark in the steering wheel and the front wheels in rack poition, it was just to put on the new shaft and the steering wheel is now in the right place without any wrong angle.
serch826 is offline
Old 10-22-2017, 06:02 PM
Cool! All fixed!
Oldblue is offline
HHRACER
06-16-2018 08:33 AM
Oldblue
Maintenance and Upkeep
16
11-01-2017 09:18 AM
intruderdct
Drivetrain (Excluding Engine)
04-03-2017 07:54 PM
MCHHR
10-04-2016 03:00 PM
webpirate
01-08-2016 01:42 AM
Quick Reply: Need help with Intermediate Steering shaft
