I have a 06 2.4L LT
How can I tell if i have a 1LT or a 2LT. Thanks nick
You can go to this site and put in your VIN, it will tell you all your options including the package (1LT/2LT)
http://compnine.com/vid.php |
also how i post a pic of car and put info under it (say like yours)
its a 1LT thanks
That's the signature, You can make the sig through your "User CP". For a picture you should upload them to the forum gallery, and then put a link in your sig to that picture. Make sure you read the rules so the pic and words don't exceed the limits.
I love it, the decoder shows my code 69 as... EXTERIOR COLOR,PRIMARY (69U)
EXTERIOR COLOR,PRIMARY,MEDIUM BEECHWOOD METALLIC (69U) That's a strange name for Daytona blue! |
Where does it show you 1LT or 2LT ?
It's called "Package option" it will say 1LT or 2LT as the option code.
its under RPO and says 1LT I guess i'm reading it right
You can also tell by the suspension code on the tag in the glovebox. IIRC, FE2 is 2lt only. might want to double check that info on here first tho
