Interior Visors Loose
I first checked the search forums and how to as well before posting but couldn't find the fix. So both visors are loose and wondered how you go about tightening them up. I noticed three screws where they're mounted and thought about removing those and then seeing what's underneath but first wanted to hear from the experts. I would greatly appreciate the how to on tightening them up. Worst case I could use some velcro I guess and go that route.
Thanks much in advance for any replies! |
It is a 2010 LT1 if that matters
There is a long thread somewhere on the subject. My solution was a binder clip, some others put a washer on a a bolt and nut, a bit of tape wrapped around the arm works for a while.
I have never done this repair, but if the visor does slide off the post you can shim the plastic bushing with a small tie rap. Or take the visor off and buy a replacement bushing.
Here's a video of a visor repair: |
I use a toothpick. :corny:
