Just Curious
So I've posted about a couple of problems and curiosities I've had with my new '06 HHR. But now I'm left wondering what cool little functions does it have to offer. It seems like a car with a lot of little hidden functions. Can anybody help point some of those out. I'd like to take full advantage of the car, with whatever it has to offer. Thanks people!
One of the great little functions on this forum is the SEARCH box which is boldly placed top center of each page.
I found you a link to the Online Owners Manual with it. https://www.chevyhhr.net/forums/gene...s-manual-3074/ Many other mysteries can also be revealed by it's use. |
Agreed on the comment on the manual. Best thing to do, is just sit down with the owners manual and read it through a couple of times. Sometimes it works well to read it, while in the car, and play with the various more complex items (such as the DIC and the stereo and all it's setting).
Here's a couple of links with some good reading for you: - changing the air filter: vhttps://www.chevyhhr.net/forums/maintenance-upkeep-50/checking-replacing-air-filter-10757/ - light bulb replacement numbers: https://www.chevyhhr.net/forums/main...numbers-38073/ - diagnostic codes from the Check Engine Light - https://www.chevyhhr.net/forums/prob...010-hhr-14259/ - a list of common problems/questions etc. : https://www.chevyhhr.net/forums/prob...d-links-38985/ - Part numbers for common and semi-common parts - https://www.chevyhhr.net/forums/comm...-part-i-48833/ Note: each of the above threads have all been made into a "sticky", meaning they will always be easily found (OR STUCK) at the TOP of each section. And don't forget about the SEARCH TOOL at the top of the page - it often can find you a quick answer to a number of questions you have. Give it a try - it works well. |
