Knock sensor
Old Feb 28, 2023 | 11:51 AM
billbryant's Avatar
Knock sensor
I keep getting a code for the knock sensor. I have replaced it and I still get the same code. Any ideas?
2006 2.4 with 290k miles. Runs great.
Old Feb 28, 2023 | 11:54 AM
The sensor is doing its job telling you something is knocking on the engine , like the air cleaner box bracket or inside, like the timing chain is stretched allowing enough change in timing to knock, or the front guide is destroyed and you need to open up that valve cover and have a look.
Has the timing chain ever been changed?
Old Feb 28, 2023 | 12:22 PM
What does "code for knock sensor" mean. Is there a Autozone code for free knock sensors? <sarcasm/>
There are at least 5 different OBD2 codes that reference Knock sensor.
Old Feb 28, 2023 | 12:50 PM
Hopefully the engine isn’t knock, knock, knocking on heaven’s door!
Old Feb 28, 2023 | 02:36 PM
greg8453's Avatar
Does that engine knock? Need exact code.
redslim73
Jan 23, 2022 07:01 PM
Bruce Donaldson
Sep 1, 2021 05:35 PM
JApow1865
Sep 22, 2020 08:12 PM
ezstriper
Sep 30, 2017 03:19 PM
