looking for Cat converter HHR 2006 Manual Trans, 2.4L
Old Jan 25, 2025 | 12:08 PM
tomasorta's Avatar
Lightbulb looking for Cat converter HHR 2006 Manual Trans, 2.4L
Hi Memebers.
I need to find a new Cat for my vehicle, the current one is rust and the join from pipe manofolder to the cat, has hole, so I tried to repair with fiber tape but is not the same, I found but always is for automatic trans even here in CAPS Canada so....
I AM LOOKING A CATALYTIC CONVERTER for my HHR 2006, 2.4L Manual Trans. if any know a good one not matter what is aftermark but with quality or used originally, PLEASE let me know. I really appreciate...
Thanks so much
Old Jan 25, 2025 | 01:19 PM
This one is good quality, mandrel bent tubing, fits both auto or manual transmission, I’ve installed in both and can confirm that it fits.
https://mufflerexpress.ca/products/c...rter-2005-2007
Old Jan 25, 2025 | 06:11 PM
tomasorta's Avatar
Thanks so much, Oldblue I will buy it and wait for better weather in Canada to install it....
Old Jan 25, 2025 | 07:15 PM
I just did mine a couple of months ago.
Old Mar 7, 2025 | 05:19 PM
tomasorta's Avatar
Hi oldblue I got the same that you sent me in the link, but did you replace the oxygen sensor both?, I replaced about 2 o 3 years ago, and every summer I clean, did you apply any thermal paste on the flange gasket to avoid a leak?, thanks so much for your help.
Old Mar 7, 2025 | 07:49 PM
You should replace both O2 sensors. They usually come with the proper compound; DO NOT use anything that has silicone in it!!!!!
Nothing needed on the flange gasket. Never use ANY silicone that could possibly get into the exhaust gasses; it will kill the O2 sensors and the cat.
Old Mar 8, 2025 | 02:19 PM
tomasorta's Avatar
Thanks for your quick reply, I found this oxygen sensor in Amazon,
A-Premium O2 Oxygen Sensor Compatible with Chevrolet HHR 2006-2007, 2.4L, Upstream and Downstream, 2-PC Set, price is just 63 $ for both
look like chinees, this aftermarket A-Premium will be a good quality?
Old Mar 8, 2025 | 02:33 PM
I don't know. I recommend NTK/NGK or Denso or ACDelco. NOT Bosch.
Old Mar 8, 2025 | 02:45 PM
tomasorta's Avatar
Thanks so much, I found in RockAuto NTK, I will bu. Thanks for your support.
Old Mar 8, 2025 | 02:58 PM
I bought the NTK from RockAuto last fall, work great!
