Losing oil through exhaust
#42
Unless you have done major "tuning" a clogged cat would throw P0420 and the car would sputter. Oil in the cat destroys the precious metals, mainly from the metals in the oil, zinc etc. Clogging comes from overheating caused by funky A/F, the media melts.
#45
Don't have check engine light on. Tuned by zzp.
#46
Well I guess I just don't understand how their system is set up to work. I would think that the end I have marked (with red X) should be connected at the valve cover vent. Based on the way the rest of your catch system is installed.
Everyone else I've seen with catch cans has them venting from the valve cover.
I just assumed by your pictures that the connection between the intake runners was a vacuum port.
#47
#48
OK now I see (I think). The inlet port for the PVC system/catch can is into the cavity of the cylinder head and intake manifold flange, doing away with the internal PCV. Flow is routed to a small water separator and then into the intake manifold.
So I'm guessing that box with the arrow on it is the PCV ? And yes it's flowing the correct way, as far as vacuum is concerned.
#49
