Low Voltage Cutoff Switch to Prevent Battery Drain
3 Attachment(s)
I didn't see any thread for this mod, so I thought I'd post. To prevent my GPS from draining my HHR's battery on those occasions I forget to unplug it from the always-hot 12v power outlet, I spliced a low voltage cutoff switch into an outlet splitter. The switch is set to cut power when the voltage drops below 12.1v, and restore power at 12.8v. Functionally, this means power flows only when the engine is running, and for a short time after the engine is shut off. I added a second splitter so that I can have at least one outlet that is always hot. The circuit is rated at 30A, which exceeds the outlet's capacity of 20A. Yes, that is a fake Tupperware tub substituting as a project box; it tucks out of sight behind the radio stack console, so looks aren't really important. I paid about $20 for the circuit from a US reseller, but it can be ordered for less from China if you are patient.
Also shown is a photo of a modified setup, fully installed. The upper bank of outlets are voltage switched, and the lower bank are always powered unless I manually shut it off with the power button above the voltage meter. |
Cool little project. Do you have links for the switch and splitter you used?
Oh, and welcome to the forum. |
Cool idea for sure. But are you positive that the outlet does not shut off once the RAP (retained accessory power) times out? I know mine does turn off when the RAP times out and shuts off. I know this because I have tapped into my outlet for a charger for my phone and it shuts off after 20 minutes.
The power outlet is not supposed to be on the RAP. Maybe some years? Maybe if you have a cigarette lighter with the smoker package?
I think the reason is for jump starting. 12.1V is a 60% discharged battery. https://cimg5.ibsrv.net/gimg/www.che...6716a6cfd2.png This is the schematic for 2007 https://cimg4.ibsrv.net/gimg/www.che...b68f9751d4.png |
Originally Posted by whopper
(Post 833932)
Oh, and welcome to the forum. http://www.ebay.com/itm/Electronics-...53.m2749.l2649
Originally Posted by 07azhhr
(Post 833934)
Originally Posted by donbrew
(Post 833943)
12.1V is a 60% discharged battery. Thanks for the schematic and the table! |
My 2008 2LT does have the smokers package and it does shut off after a short time, I used it for the cell phone charge and it did not finish charging so I know what happened.
I have a 2011 LT and I believe mine stays on. I have left my GPS plugged in and it charges will the car is off.
Originally Posted by CA Blue HHR
(Post 833967)
My 2008 and 2011 both stayed on. I think it is another difference between a cig lighter and a 12V power outlet.
I put a priority start protector on the my car. If I leave something on or just don't drive the car for a long time I can just get in and start it. Never had a dead battery since I installed it. :thumb:
