Moving to a new state! Have to tow the HHR, any tips?
I'm renting a Uhaul with a tow dolly. I figure this is as good a place as any to ask for towing advice for this specific car. Do's and dont's. Common easily avoided disasters. That kind of thing.
With a tow dolly , check your straps often, don’t ever try to backup, and follow the directions to a T.
I used to rent those tow dolly’s and some came back damaged I didn’t see the vehicle that was towed but I saw the police report from a renter that, lost his car, because he didn’t think the straps needed to be that tight, and with straps, who needed safety chains! |
Originally Posted by Oldblue
(Post 848606)
Great, then you’ll be just fine! Enjoy the drive to your new home!
Ratchet the straps until the tires start to squish a little. They need to be TIGHT. Your tire flexes a few times a second going down the road, so it wont mind a nice hug.
(Post 848630)
Originally Posted by aradmahogany
(Post 848632)
Yeah I'll tighten them as much as I can and redonit each time I stop. |
after driving a few miles check straps i found a few times that they were loose
And check your rear lights functioning to be safe.
& besides the tie-downs, check the hitch hook up etc. Tow-Dollys are easy to use, just best to check things often & arrive safely. |
