Mud Flaps
Who has the best after market Mud Flaps. I found one called "Contura" but can't tell if they are good. Should I stick to the GM Brand?
To me it would all depend on the price of the aftermarket part AND the quality of the parts. At gmpartsdirect.com the molded front/rear set for the HHR is $58.44. Here is the part #12499528.
I have these on my HHR, they were a dealer installed option and they are great. |
+1 for the factory molded ones. They are easy to install and fit great. They finish off the wheel well too. I have a summit white 08 and the black contrasts real nice off the white w/ polished 17's.
I purchased the GM Contoured Splash Guards (Mud Flaps) for both my HHR and my fiance's HHR...
They are a perfect fit and look real sharp!! :thumb: Even painted the "HHR" lettering on both with matching touch-up paint to give a bit more style to them. Highly recommended... |
Thank you all. I also have Summit White (Panel style) and I went through some small puddles and it really made a mess without the Flaps.
HipHotRod is correct...
They are a perfect contrast on the Summit White HHRs... ;) |
I also picked up the molded HHR mud flaps and the Stainless wheel well trim should be interesting to see if they work together. Has anyone else installed this combo?
Bought mine from ChevroletPartsPeople.com for $55 (front and rear)I believe it was. OEM then painted them. Very Easy to Install.
Originally Posted by Cajun
(Post 281144)
