Nice job, Redshift. And the result looks really nice.
I did half my floor (the motor head side) almost 3 years ago. I used a concrete stain with a industrial grade poly satin sealer (a friend with the required license purchased it for me). It's held up very well and makes spilled oil/fluids a snap to wipe up. I also spent about 5 days for the total application including the power wash, acid etch, power wash, adhesion promoter, the stain application and clear coat. I didn't drive on it for another 2 weeks The key to ANY floor coating is the prep. I did much as you did, however, I also had to use a strong cleaner on previous oil spill spots, before the first power wash.. Every thing seemed to work well, again, because of no chips, stains or peeling. Will probably do the other side, which is the "woodworking/handyman" side this spring. Curious, I also have a lift. Which one did you select? AND you will never regret owning one.....even for an occasional vehicle job. Oh one thing I should mention......Mine is somewhat slippery when oil is spilled or when wet. I wash mine frequently with a hose and "squeegy" the water out the overhead. |
Originally Posted by Snoopy
(Post 505000)
I did half my floor (the motor head side) almost 3 years ago. I used a concrete stain with a industrial grade poly satin sealer (a friend with the required license purchased it for me). It's held up very well and makes spilled oil/fluids a snap to wipe up. I also spent about 5 days for the total application including the power wash, acid etch, power wash, adhesion promoter, the stain application and clear coat. I didn't drive on it for another 2 weeks The key to ANY floor coating is the prep. I did much as you did, however, I also had to use a strong cleaner on previous oil spill spots, before the first power wash.. Every thing seemed to work well, again, because of no chips, stains or peeling. Will probably do the other side, which is the "woodworking/handyman" side this spring. Curious, I also have a lift. Which one did you select? AND you will never regret owning one.....even for an occasional vehicle job. |
I've used a few of these epoxies and I'm done with them. They simply don't last. Hot tire pick up, salt destroys them, etc. My garage is currently a chipped version of above, otherwise I would probably consider stain instead. But I will probably go with a rubber flooring. That way if you move you can take it with you. If you destroy a tile you can simply replace it. Only negative is that it get's expensive.
Originally Posted by Gas Man
(Post 505026)
I'm hard on a floor. LOL When we bought the New place the floor was sealed. And that is slowly wearing away in the 'action areas' ..:skull: |
Ipicked up a Great Garage Makeovers nagazine ( from editors of WOOD magazine) and they go over many different types of garage flooring...including tiles! Very informative..a few examples included decorative floors that have a few years on them with no problems..
also cover lighting and clutter... |
Originally Posted by sleeper
(Post 505114)
Rubber is too easily damaged by weight on jackstands etc.. & Headache to roll bikes around on lifts & etc.. Just not for me. Although I do have anti-fague mats in front of my work benches & various areas..
Red,
At least from the pictures your floor looks fine, I’m always the pickiest of all those who view my work too. Do have one question about your garage though. Why are the electrical, plumbing and some pipes coming up out of the slab floor and not through the stem walls? They seem to be looking for trouble with things hitting them in the future and a waste of space to boot. Is there something in your local building codes or environment that requires this? Or was it a lack of forethought from the builder to get them into the stem walls? Like those golf shoes! |
Originally Posted by Sno White
(Post 505761)
Like those golf shoes! Those are lawn aeration shoes :) Some pics: http://www.smugmug.com/House/Garage/...41_X2YYX-L.jpg http://www.smugmug.com/House/Garage/...01_QVVfQ-L.jpg http://www.smugmug.com/House/Garage/...30_4tEEP-L.jpg |
Wow
Thanks for supplying the pictures, that is how I see many floors built in commercial buildings.
One more question: Is the lift going to be supported over some of the I-Beams? |
(Post 506300)
| All times are GMT -5. The time now is 08:16 AM. |
