need help--removing door panels
what am I going to run into? do I just pull it off or are there things I need to disconnect? any info related to this is helpful. Thanks |
Thanks Mike....
I need to know this also. |
There was a thread to this, but it seems to be blocked by the administrator of the site. (here)
check out Captain Howdy's speaker swap in the How-To section
Got them off. Two bolts in each door pocket and then one behind the handle. Then it comes off real easy. |
These are instuctions from repair manual. for door panel removal, hope they help.
1- Door armrest,pull cup liner. 2- Remove 2 cup screws. 3- Door inside handle cover. 4- Remove door handle screw. 5- Remove door panel, there are 9 panel clips. Hope this helps, if you have'nt already figuered it out. Can send a diagram if needed.;) |
sorry I see you already have it, gave me a chance to post a reply.
