Coolant recovery tank
Old 01-24-2016, 06:02 PM
BQS4's Avatar
Has anyone swapped one of these out? How difficult?
BQS4 is offline
Old 01-24-2016, 06:20 PM
Technical Moderator
1 bolt on the top, bayonet at the bottom.
donbrew is offline
Old 01-24-2016, 06:22 PM
You don't state the year, so I'll assume you have the "overflow" tank and not the surge tank that was on the early HHR's.
Either way, it's an easy swap.
firemangeorge is offline
Old 07-18-2017, 08:26 PM
smanzo22's Avatar
Can anyone point me to where I could find instructions on how to take the recovery tank out? I took out the bolt and the clamp at the bottom but still can't seem to pull it out. What's the trick here? I have a 2010 LT model.
Appreciate any help anyone could give.
smanzo22 is offline
Old 07-18-2017, 09:34 PM
Technical Moderator
No trick the bolt at the top is the only thing holding it, the bayonet at the bottom goes into a slot in the sheet metal.
donbrew is offline
Old 07-18-2017, 10:18 PM
Pull and wiggle. Wiggle and pull.
Careful that you don't scrap off any skin when it pops free.
Old 07-19-2017, 09:43 AM
Yep, one bolt and wiggle and pull, and pull and wiggle.
https://www.chevyhhr.net/forums/main...servoir-48984/
Oldblue is offline
Old 07-19-2017, 10:22 AM
aradmahogany's Avatar
Not to be picky but, doesnt the tank slot go into the radiator fan shroud? Mine did at least when I had to replace my fan. It came out very easy either way.
aradmahogany is offline
Old 07-19-2017, 11:30 PM
smanzo22's Avatar
Haha alright, fine I'll keep at it. Just seems too stubborn! Thanks everyone!
smanzo22 is offline
SSROADSTER
43
03-07-2022 08:46 PM
redhhr08
08-24-2020 08:43 PM
lisasvette
09-01-2015 11:25 PM
bt0210
09-01-2015 07:17 PM
Diskokid
01-02-2009 12:49 PM
Quick Reply: Coolant recovery tank
