Oil Change - Reset help
I just had the oil changed from the dealer and the Oil Life still says 16%. I tried resetting it but it still says 16% am I missing something on resetting the thing? Unless, of course they forgot to put more oil in.:confused:
Originally Posted by vschriver
(Post 270397)
1) Turn the ignition to ON/RUN, with the engine off. 2) Press the information and reset buttons on the Driver Information Center (DIC) at the same time to enter the personalization menu. 3) Press the information button to scroll through the available personalization menu modes until the DIC display shows OIL-LIFE RESET. 4) Press and hold the reset button until the DIC display shows ACKNOWLEDGED. This will tell you the system has been reset. 5) Turn the key to LOCK/OFF. |
You can also turn the ignition to the "run" position with the engine off.......depress and release the accellerator pedal three times within 5 seconds and then turn the key off. I guess that's for those of us who are "push button challenged".
Brad To Da Rescue!
double secret button pushing does not get me into menu. i must do the gas pedal trick for access.
2 Attachment(s)
Originally Posted by ilgallo
(Post 270434)
Here is the 2007: Attachment 3009 Here is the 2008: Attachment 3010 |
I used the KEY ON depress pedal 3 TIMES key OFF trick.
5 seconds later, I was at 100% |
Originally Posted by Smoke Wagon
(Post 270442)
got it to work, thanks
It worked for me either way the dealership should be doing this once the oil & filter have been changed its part of their routine check. I always check before I leave the to ensure they did it just to make sure that they did do the work!
