Oil life reset issue
I had the oil changed on saturday...I can't get the oil life to reset on the DIC. Just filled it with gas and reset the trip, avg mpg and speed, but the oil life won't reset. Anybody else ever run into this?
Did you check the manual... there's a procedure to it..... :skull:
Turn the key to the 'on' position (do not crank it), step on the gas pedal three times.
That's the other procedure, not covered in the manual.....
Originally Posted by 1970judge
(Post 567699)
(Post 567699)
OR.................
1. Turn the ignition to RUN, with the engine off. 2. Press the information and reset buttons on the DIC at the same time to enter the personalization menu. See DIC Vehicle Personalization on page 200. 3. Press the information button to scroll through the available personalization menu modes until the DIC display shows OIL-LIFE RESET. 4. Press and hold the reset button until the DIC display shows ACKNOWLEDGED. This will tell you the system has been reset. 5. Turn the key to LOCK. If the CHANGE OIL SOON message comes back on when you start your vehicle, the engine oil life system has not reset. Repeat the reset procedure. From the manual. :lol: |
Well, the directions from the manual didn't work, but stepping on the gas three times did. Stupidest thing I've heard of yet on these cars, but it worked. Thanks for the tip!
Originally Posted by SmootHHR
(Post 567791)
My wifeys Mopar Oil reset is that procedure exactly.. :wink: |
SmootHHR,
I am glad that you were able to use the information that was provided to you by your fellow HHR owners. Thank you every one for jumping in and helping SmotHHR. If you have questions or concerns, don't hesitate to contact me. Michelle, Chevrolet Customer Service |
