Don- Ooops !! I missed that in your sig. Thank You Sir. :twothumbs:
Where to find the replacement interval of the chain?
In here it’s discussed, no real interval , just cheaper to change the chains and guides , then replace bent valves or damaged pistons , or complete engine. after 125,000 miles you have to ask yourself, do you feel lucky? Well do you? |
Now 168,000 miles. It is necessary to check. Thank you.
At that mileage, if you take it apart to check, continue and change the timing and balance shaft chains. https://www.chevyhhr.net/forums/how-...in-kits-60394/ |
I needed this thank you so much!
Nothing like a good owners manual, & then reading it..
