Only got 11 years on the original battery 2007 HHR
Yep. I'd be looking in different locations. GM still makes an AC Delco replacement, cost is $130.
Interstate has one, $135.
All the auto parts chains have them, bout same price range, although Advance auto is higher.
My wife's 2006 has low mileage, 103,000, and I had to replace the battery the other day. I am very satisfied with a factory battery that lasts more than 5 years. I remember when you were lucky if you got three winters out of the factory ones.
#27
Hey Sleeper, When my battery in the '08 went bad ,after I replaced it, the tire pressure on the DIC went - - - - and the key fobs didn't work. Donbrew said because it is an '08 ,I had the get it reprogrammed at the dealer. I did. they did the tire sensors and front door locks with their hand held device, but had to use a lap top to program the back side door poppers. No charge, so I was a happy boy! john
