Outside Temp Gage - Accurate? :)
Old 06-30-2008, 06:20 PM
chevyorange's Avatar
My temp gage is always cheating at least 5 degrees high and some days I swear 10 degrees. Does anyone know where the sensor is for this? I hope it isn't the same as the headlight sensor on the dash!
Does anyone know how to adjust this?
I'd love your two cents.
chevyorange is offline
Old 06-30-2008, 07:09 PM
edb
edb's Avatar
The weather forecast temperature is always different from the road surface temperature. Road surface temp is usually higher, and is the real temperature you feel, I guess the sensor measures the real temp.
edb is offline
Old 06-30-2008, 07:11 PM
I am going from my gage on my back porch, 20 feet away from my HHR!
It consistently shows 5 degrees higher. I understand that the pavement is going to be hotter - that is why I was wondering where the temp sensor is!
Old 06-30-2008, 07:43 PM
an08HHR's Avatar
most home thermometers aren't accurate anyways.
Here is the location on the HHR https://www.chevyhhr.net/forums/show...sor#post237100
an08HHR is offline
Old 06-30-2008, 09:04 PM
Cyclic Hardover's Avatar
Mines close or not enough for me to worry over it. If I get into the car and its hotttttt and start it up and says 85plus, its close
Cyclic Hardover is offline
Old 06-30-2008, 10:29 PM
Li'l Hearse's Avatar
My HHR is black and sits in the sun. On those days it'll read alittle high and start going down after a few minutes.On cloudy days or at night it reads the right temp
Li'l Hearse is offline
Old 07-01-2008, 06:13 AM
REDFLYR's Avatar
go to hardware store... look at all the temps on the shelf
i like the ice on road warning
REDFLYR is offline
Old 07-01-2008, 06:58 AM
pitbull76's Avatar
Mine will show higher temps when it has been sitting in the sun, but once underway its temp readout is pretty accurate.
pitbull76 is offline
Old 07-01-2008, 07:36 AM
Ratzilla's Avatar
wonder if they have included.
Hot enough to fry egg
curtsy
Elle'
Ratzilla is offline
Old 07-01-2008, 07:55 AM
Vinny's Avatar
I'd like mine to just say cold -chilly - comfy - warm - and get out of the car and into the pool
Vinny is offline
Quick Reply: Outside Temp Gage - Accurate? :)
