Painted my calipers and rotors
The stock calipers and rotors were starting to look pretty bad. So I rotated the tires and painted the calipers, rotor hats and rear drums. It took about 4 hours and a can of high temperature gloss black spray paint.
Before https://www.chevyhhr.net/gallery/fil.../8/312a0wk.jpg After https://www.chevyhhr.net/gallery/files/5/9/8/6jhgdu.jpg https://www.chevyhhr.net/gallery/files/5/9/8/fwlkbm.jpg Added a stainless steel exhaust tip over the tiny stock one. https://www.chevyhhr.net/gallery/fil.../8/23h16ps.jpg https://www.chevyhhr.net/gallery/files/5/9/8/epnj84.jpg |
Looks good!
looks good. What brand of high temp paint did you use?
Finish up by painting that damn roasting pan muffler....I did.
Don showed me his painted black, and it disappears in the shadows. Cajun |
Originally Posted by outlandishhhr
(Post 322435)
Rustoleum High Performance V2100 System Enamel Aerosol The ultimate spray paint for industrial applications. Provides maximum corrosion protection and long lasting durability. High paint solids provide excellent coverage in one-coat Dries fast — 20 minutes to touch 20% faster than other brands Superior gloss retention Tough, professional finish provides superior resistance to chipping, cracking and peeling Can be used on surfaces that reach temperatures up to 200°F Most colors match Rust-Oleum Industrial Enamel gallon products for convenient touch-up |
Originally Posted by Cajun
(Post 322449)
Cajun :roflol: :roflol: Good idea. I will get started on the roasting pan today. |
Did this come in other colors???
and yes, PAINT THE ROASTER!!! ;) @ngelita |
Was it hard to paint the calipers and drums (masking off everything?)
Looks good! Yes--paint the muffler... (I used BBQ paint!)...
Caliper paint is on my x-mas last, and i'm pretty sure santa is bringing it.
I haven't used it yet, but from all the reviews i found, i went with the G2 kit. Lots of colors for you, a 2 part paint you mix to create an enamel. Takes 24 hours to cure. I think it's around $40 for a set. I found tons of reviews on that and the duplicolor set and the G2 won hands down. free shipping here and a coupon code to get an extra %5 off. best deal i could find. twice as much as duplicolor, but you're paying for the quality. http://www.wheelskin.com/g2_brake_caliper_paint.html Lots of people that used the duplicolor set had it cracking and flaking in a year and then re did it with the G2. Found all the info on some mustang, corvette, and lexus forums. |
you dont got to mask off to do rotors i just held newspaper up as i sprayed :) didnt get any on the rotors or anything else..
and paint the muffler.. get engine or bbq paint |
