PANEL: rear power outlet same as the power plug?
Hello,
I was reading the 2011 Owners manual from GMs web site and in the Panel section they mentioned a power outlet at the rear in which you have to remove a panel to plug into a socket for power tools? Is this the same thing as the rear cigarette power plug on the aft pilar? Or is Chevys web site/Owners manual just missleading? If they are diffent whats the build code? From Chevys web site: Cord going behind panel "Chevrolet HHR Panel features a rear power outlet for electronic equipment requiring up to 40-amp battery service" https://www.chevyhhr.net/gallery/fil...hrp_int_05.jpg From the oweners manual: Rear Power Plug for Converters The vehicle may have a power plug connector located in the rear cargo area on the passenger side behind the service panel. The power connector wiring can be accessed by removing the service panel to begin installation. This plug can be used to supply power to commercial converters and contains four different circuits. The functions of these circuits are as follows; a 40 Amp battery service, a 10 Amp Accessory or Run service, a 15 Amp Delayed Accessory service and a Ground circuit. I removed my cover (Panel HHR) and I have a big 4 blade conncetor hanging..with a big power wire going to it? |
Originally Posted by Pretzel
(Post 581492)
Is this the same thing as the rear cigarette power plug on the aft pilar? I removed my cover (Panel HHR) and I have a big 4 blade conncetor hanging..with a big power wire going to it? |
The 4 blade connector probably accepts the power unit inverter...
Idk |
Dear Pretzel,
I have read about your research for the power outlet in the rear of the HHR. Please, allow me up to 48 hours to exhaust my resources and get you better understanding about this feature. Michelle, Chevrolet Customer Service |
Originally Posted by nacademus
(Post 581527)
Idk
(Post 581492)
converters and contains four different circuits. The functions of these circuits are as follows; a 40 Amp battery service, a 10 Amp Accessory or Run service, a 15 Amp Delayed Accessory service and a Ground circuit.[/I] |
1 Attachment(s)
Helllo,
After some reseach of my own I can put somethings together. 1> RPO codes for all the PANELS lists: :Power outlets, 2 auxiliary, 1 front and 1 rear :Power outlet, 1 in the cargo area :Rear power plug connector, 40 amp battery service circuit with 10 amp accessory or run service circuit, 15 amp delayed accessory service circuit and a ground circuit. Designed for installation of electronic equipment that requires up to 40 amp battery service My plug has 4 wires...the pos and neg wires are 12 gauge and the others are 18 gauge. The manual tells me what they are. This plug can be used to supply power to commercial converters and contains four different circuits. The functions of these circuits are as follows; a 40 Amp battery service, a 10 Amp Accessory or Run service, a 15 Amp Delayed Accessory service and a Ground circuit. My plug with white paper background. Attachment 28232 Ok what the heck plugs into that for comercial use? Surley not a blender :lol: Thanks, |
Not a blender by any means, you can hook this to a power inverter that takes the current from the HHR and steps it up into AC power for tools and electronic equipment. Click the link below for an example of a commercial power inverter/converter that would work in an HHR.
http://www.realworktrucks.com/power-...1000-watt.html |
So, what everyone is saying is : you need to buy your own inverter and go to the dealer to buy the power "pigtail" to plug into the existing wiring connector. one of the circuits is switched and one is constant and one is on the "anti-lockout delay" and the 4th is ground.
Times up
Does anyone have the part number for the "dealer supplied pigtail"?
