Parts breakdown list
https://www.chevyhhr.net/gallery/fil...5/SANY0004.JPG
Looking for a link, or info on needed parts so I can do the needed repairs. I have located a few items such as, bumper cover, fender, headlight, turnsignal. Thinking I can save the hood, but have located one of those also. Needing info for the rest of the parts in that area. Braces, brackets, plastic panels, what ever else. |
Hmmmm, 135 views and nobody has "any" info?!?!
Like I said, located all of the outer parts, need info on the braces, brackets, panels that are hidden by the outer panels, but what is what one needs to effect repairs. |
Other than the obvious.....scrap yard suggestion, have you tried the obvious local dealers. Or the obvious, on line OEM parts suppliers like:
www.gmpartsdirect.com www.gmpartshouse.com I say "obvious" because you give no indication of what you have tried AND the parts you are apparently trying to locate appear to be limited to OEM products. Hope it helps....good luck. |
