| kmdakota1 |
Mar 31, 2026 09:22 PM |
Power bleeding brakes
I've been wanting to get around to a good brake fluid change and bleed. Ordered a Motive power bleeder on amazon. In the past, i've just used a compressor with a DIY cap to pressurize the reservoir but the compressor is old and there's a lot of moisture in it now.
I do have a bidirectional scan tool that has an abs brake bleed procedure. I've used it before but never knew if i'm supposed to press the brake pedal when it prompts you too or not. Everything i've read says you do not need to press the brake pedal. However, if I don't press the pedal when in the abs bleed mode of scanner, the abs pump does not turn on.
So, does it hurt to do light presses on the brake pedal while the power bleeder is on and not let the pedal go all the way to the floor?
