Premium Gas??
If you have the 2.4 Chevy recomends 91 octane. If you have the 2.2 they recomend regular. I always use 93 octane no matter what the manufacturer says.
Why doesn't you dad like premium?
If you love your vehicle it deserves the best!
I'm sure the Bentley Continental GT you were looking at recomends premium.
Although they (chevy) do recomend 91 octane they (Chevy) say you can still use 89. Myself personally, I run 91. If you purchase an HHR I would definitely recomend buying the 2.4L. The word on the street is that not many aftermarket companies are going to cater to the 2.2. Good luck!
It wasnt us looking at the Bentley, it was my aunt. Premium is more money. The savings would not be significant. He wants to save $$ on gas because his car gets 17 mpg, but if the gas is more on the HHR, you wont be saving much.
As mentioned above, Chevy does recomend premium. You could probably put mid grade (89 octane) and still be ok, as long as you don't get ping. It would truly be a shame to miss out on a great car becouse of premium gas.
Originally Posted by HHR4LSU
Don't most gas stations only have 89 or 93 though? Not the 91....
Go with the 93
Go with the 93
There is an octane sensor in the HHR's fuel system which the PCM uses to adjust engine timing.
I haven't found a reason yet to run the more expensive fuel in my 2.4L. I ran a few MPG tests using both 89 and 93 octane fuel and didn't see any difference at all. Both tests were on a 320 mile round trip, mostly highway crusing.
May be in the summertime the higher octane fuel will offer better performance, I'll have to wait and see...
