Pulsating brakes, need advice
Old Feb 17, 2019 | 10:47 PM
I recently put a set of ceramic pads on my Mrs Mopar. They have been properly bedded & she loves them, quiet & more importantly, stop well.
Happy with them, & did brake fluid flush at same time.
Old Feb 26, 2019 | 02:11 PM
PulpFriction's Avatar
I remember reading in a GM bulletin somewhere that dealers are advised when confronted with complaints about pulsation, as a first step, to make three hard stops from (40MPH, if I remember correctly?) allowing the for some cooling time between stops. This actually makes sense, because the heat could free the calipers plus if the car's been parked for awhile, the rust on the rotors ain't uniformly distributed. Anyway, it works for me; I always babied my brakes and was always confounded by pulsations. Now I have an excuse for driving deep into corners and fun hard stops.
The same source said if the above didn't work, check rotor TIR and I was surprised how low the limit was; .001 or .002" maybe? I don't remember exactly. They also emphasized that rotor replacement was NOT recommended unless thickness was below service limit and that all the rotors need not be equal in thickness.
Old Feb 26, 2019 | 02:23 PM
Cat Man HHR's Avatar
I replaced my front brakes at 30K? Best pads and rotors from Advance Auto. Car now has 55K and have rotor pulsation. I mostly do around town driving which is stop and go. I'm sure this helps in making the rotors non-concentric/parallel surface. As a test I'm going to try vented rotors when the weather gets warmer so I can change them out. My thought is it will give the rotor quicker time to cool down between brake applications.
Old Feb 26, 2019 | 08:35 PM
Don't forget to check & adjust as needed the rear drum brakes (non-SS models only)..
Mine has 33K & stops smooth as silk, all original brakes.
Old Feb 26, 2019 | 09:13 PM
Assuming it’s Cat Man’s SS then Power Stop has a kit of four rotors and pads with hardware.
https://www.rockauto.com/en/catalog/...+pad+kit,13824
For the standard SS , not The Brembo package
Old Feb 28, 2019 | 06:23 PM
Silverfox's Avatar
X-2 ,..... My 2LT has 42,000 and is also smooth as silk in stopping. Just adjusted rears ...3 clicks.
SF
Old Feb 28, 2019 | 08:42 PM
vairman
Oct 27, 2016 06:56 AM
HisAndHearse
Oct 24, 2016 09:53 AM
pettyrules
Jun 30, 2016 04:38 PM
Doc brown
26
May 28, 2014 08:17 PM
arttysHHR
Nov 13, 2010 11:11 PM
