radiator damage question
The A/C condenser is mounted in front of the radiator so what your looking at should be the condensor, there's about an inch of space between the condensor and radiator. If it is then make sure your A/C is working properly, if it has just the slightest leak the freon would be gone in a flash. If it's working ok then you can just live with it if the looks don't bother you.
hvrod you know that Chevys not going to replace it because it was caused by something hit in the road. It's not Chevys fault in any way. The front opening on the HHR isn't that bad compared to some vehicle and it's worse than others. Deal with it, you bought the HHR knowing what size the opening is. omega015 go out and take some pictures then upload them to a site like photobucket and paste them to this thread. In the future you might want to add aluminum mesh like hvrod or a billet lower grille like myself so this doesn't happen again.
then... suck it up after that...
I'd buy a Billett grille for it to keep it from any further damage. I ordered one from Mike at SoCalHHR the other day along with a couple other things I wanted. Don't want to take any chances of something like that happening to my HHR. His grilles are very reasonably priced and well worth the investment.
ChevyMgr
Aug 23, 2012 11:55 AM
unique_w
Sep 10, 2009 01:21 PM
jcbrowns
14
Feb 26, 2009 12:44 AM
