Chevy HHR Network
-   General HHR (https://www.chevyhhr.net/forums/general-hhr-4/)
-   -   radio controls (https://www.chevyhhr.net/forums/general-hhr-4/radio-controls-59351/)
kustom Sep 7, 2017 09:59 AM
radio controls
getting a used stering wheel from junk yard with the radio controls what else do i need to get to make them work ?
do i need get the radio also ?
cables ?
thanks john
donbrew Sep 7, 2017 10:08 AM
Absolutely everything on the subject is here:
https://www.chevyhhr.net/forums/how-...ng-wheel-1912/
kustom Sep 7, 2017 10:31 AM
donbrew thanks again
Oldblue Sep 7, 2017 01:12 PM
Should be plug and play, mine was!
prod Sep 7, 2017 09:08 PM
There was a wiring change at some point, so if the wheel is from a different model year it may involve switching some of the wires around in the connector.
That said, I was fine swapping in a pontiac wheel from an unknown year without any alteration.
kustom Sep 7, 2017 09:21 PM
same year thanks
donbrew Sep 7, 2017 11:21 PM
Just look at the wire colors; they changed the positions in the connector at some point but the color codes are the same.
Make sure the colors are the same on each side.
kustom Sep 8, 2017 06:27 PM
thanks will do
