rear hatch
Old Oct 23, 2023 | 11:16 PM
treasureman's Avatar
rear hatch
has anyone put in a key lock on the rear hatch ?..like taking the front door lock and drilling a hole at the right location and adding a link-arm ?
Old Oct 23, 2023 | 11:20 PM
Why ? What is the reason for wanting to do this ?
Old Oct 24, 2023 | 06:49 AM
Not that I remember.
Old Oct 24, 2023 | 07:56 AM
to the forums!
The hatch latch isn't like the door handles. It's electric. When powered up,the hatch will open. When the doors are locked electrically, then power is not supplied to the latch.
So if you install a key cylinder, I'm not sure how you could use it to power the switch or otherwise open the hatch.
Old Oct 24, 2023 | 10:48 AM
Perhaps a keyed switch, but if the battery dies then it won’t work.
If it’s your touch keypad has failed, order one online or shop at your local pic a part.
Old Oct 24, 2023 | 12:28 PM
If All doors are locked the liftgate should be locked. If there is a fuse in position #11 in the under hood fuse box the lift gate will not lock.
You can lock/unlock All with the button on the front doors or with a fob 2 presses of the lock button.
Old Oct 26, 2023 | 10:30 AM
PulpFriction's Avatar
Never heard of one, but if someone came up with good strictly mechanical key hack for the hatch, I think there would be plenty of interest, especially if it did not disable the solenoid actuator.
The solenoid-only system might have made sense if there was a remote option. As it is, just a simple mechanical key lock would prolly have been cheaper and better.
Only a strictly mechanical solution would be of much use.
An interior pull tab or string would be handy too, but not as useful.
The fuse-in-11 is handy to know about, but of no help with a dead battery or a failed latch solenoid.
I have seen a remote hatch latch retrofit. It was on a custon shaved hatch. It had a dedicated fob. I woulda just relocated the switch to a hidden location.
I have considered adding a second hatch switch, located on the dash panel. Another option that just occured to me is a toggle on the dash that would do the exact same thing as the #11 fuse, but allow convenient instant selection. Or how about both?
Old Aug 12, 2025 | 04:47 PM
tboxx7714's Avatar
If there is a fuse? Or if the fuse is blown. My son's hatch won't lock on his 2008 LT.
Old Aug 12, 2025 | 05:44 PM
There should be no fuse in #11.
Old Aug 13, 2025 | 05:36 AM
geg's Avatar
geg
I also like the idea of opening the trunk without a solenoid,
but the only thing I could think of was to free up a gap in the trunk gate trim and attach a loop to the lock mechanism.
But this is only half a solution, it does not provide access from the outside. The only plus - is to close the gate from the inside, for example, if I went to bed there.
