Replacing Stabilizer bar bushings
Old Jun 1, 2011 | 10:44 AM
diskullman's Avatar
Can replacement of the stabilizer bar bushings be done on ramps, leaving the wheels on? I'm thinking I can unbolt both bushings and wiggle the bar down enough to remove and replace the bushings. Anyone know for sure?
Old Jun 1, 2011 | 11:02 AM
geg's Avatar
geg
if you unscrew the links - yes
Old Jun 1, 2011 | 12:00 PM
Zagohhr's Avatar
I replaced them. I tried first with ramps, but really is a pita in due that there´s not clearance for the front screws. Then, I removed the wheels and was easier. And as Geg sez, you need to remove one of the two link bolts.
kmcrae476
37
Feb 28, 2025 07:49 AM
R CA HHR
37
Aug 6, 2019 08:15 AM
joeg.satx
Jan 22, 2011 11:54 PM
chocolatefonz
10
Nov 25, 2009 09:17 AM
