Resetting check engine light.
Does anyone how to reset the light? My girlfriend drove home from the gas station with the the cap off and triggered the light. I dont want to go to the dealer to reset it! I'm very busy all the time (just like everyone). And it seems like every trip there is an all day experience..
I have heard that on other vehicles, if that happens, just put the cap back on and after several engine starts, several days, or some such, it will go away.
There is info in the owners manual regarding that issue! Heck if I remember what it said, I know it's there though!
It happened to me and the dealer said after 10 starts of the engine it will go away and did!:nuts: :nuts:
If you happen to have the new CAN OBD code reader, you would be able to reset it within a few minutes...
Stop by , and I'll do it for you.. |
Only one problem; by the time he got there from Ohio - it would be reset already! What a waste of gas that would be.
I have the new locking gas cap and my check gas cap light came on today and then the check engine light came on and will not go off. Will disconnecting the battery fix this problem? Or should I just drive it until it goes off...hoping it's nothing else? HELP!!!
PS...I put the old gas cap back on for now. Guess I didn't have it on securely when I put gas in it the last time and it worked itself loose. |
PS...I put the old gas cap back on for now. Guess I didn't have it on securely when I put gas in it the last time and it worked itself loose. But maybe you have another issue. I think if I were you I would run it in for a diagnostic in case it is purely conincidental to you having the different fuel cap. Not sure I would want to drive it as much as is apparently needed to get the light to shut off when triggered by the gas cap if I was not positive it was caused by the cap. |
