Thought of using a VOM? Power seat fuse is #37 underhood. heated seats is # 23 underhood. 12 place connector , black wire is ground red/white wire is 12V. If there are more than 2 wires on it you may be wired for heated seats (look for an extra connector near the AC control.
Sorry my VOM has no mention of a electric seat hence why I asked it reads blank and my underhood cover legend also reads blank. Thanks for the information what fuse size should I use ?
23 and 37 read blank in VOM and cover legend.
"my VOM has no mention of a electric seat" Hmmm. I'm not even sure what that means.
#37 is listed as a circuit breaker in the wiring schematic. I pulled mine out and laid it next to the socket it plugs into. That thing is about 2 inches wide. Notice it's large size compared to the mini fuses and relays.
Small label on it shows 30 AMP 14 volt.
Thank you all I now know what I need to buy just need to find a place that sells them most auto parts guys should be able to get it for me I guess, I hope I don't have any further questions. Thanks FMG for the picture
