Service traction, abs, Tc, cel wtf lol
So cel has been on due to evap gas leak... let wife drive 1 time and I got back into a Christmas tree dash..
now says service traction, Tc, cel and abs. All the stores are closed to get codes read so I guess I'll see if any new codes tomorrow and post the codes... 07 2.4 lt. |
Already read lengthy how to.. https://www.chevyhhr.net/forums/how-tutorial-library-21/camshaft-position-actuator-solenoid-valve-replacement-w-pics-p0010-11-p0013
even changed the parts, did all the week 1 of getting this hhr. |
Also brake fluid is good. Both front rotors are new and pads are new, a long with slides for the calipers.
reading all the searched material now. it did do the low traction other day on dry pavement then surged forward. |
First guess is something wrong with a wheel speed sensor.
I know steering wheel shakes now and when braking its yanking to left and nose diving. Going tomorrow to get cel read
Check hub wiring for the ABS. |
I had the codes pulled, still just the Evap codes...
So I think im gonna pull the shocks, springs and front set up off of the wrecked HHR. I picked up new inner/outer tie rods.. I guess pick up 2 new wheel hubs, and rebuild the front end and see what happens. Check all the wires while im under there, see if any chaffing or nice little critters bit into them.. |
You comment in #5 leads to severe brake trouble.
Originally Posted by donbrew
(Post 852829)
Kindf of like the passenger side is NOT working instead of the driver side working too good? That would cause the ABS related things because one wheel is turning at a different rate.
