Shimmy at 60mph???
Interested if anyone else is experiencing the same issue I am....? I've got a 2LT with the (OEM) polished 17's and approx 1900miles on my HHR. I've always noticed a slight shimmy (or shake) when I approach the 55 - 60mph range.
Logically- took it to the dealer advising the front doesn't seem to pull one way or another (eliminating an alignment issue) and stating it only occured at a specific speed. Well - they pulled the wheels off and re-balanced stating they were 'all out of balance *a little*'! :eek: What exactly that means, I'm not sure- I always thought wheels were either IN balance or OUT... period!? Well - turns out THAT wasn't the issue!!! :mad: Hell- I don't even think the dealer took the vehicle out for a test drive after balancing!?!?!:wtf: Curious if anyone else is, or has, experienced this issue with your HHR? I've wrenched on my fair share of vehicles over the years, and although I'm no mechanic- I'd like to think my dealer's NOT that cheap and incompetent (right :scared:) !!!!! |
Nope. ;) No shaking with my HHR at well over 60. :smile:
alignment or balance usually causes that
shaking when braking is warped rotors good luck |
Mine rides like a Buick at 70 mph.
The other possible item... it shouldn't because their brand new......
tie rod ends or ball joints... |
I think it's the Firestone tires. I noticed that shimmy when I hit around 60 MPH while the car is still warming up (a highway 1 mile from home). However after the tires got warm, the shimmy goes away.
I got rid of those tires long ago..
After the first encounter of the rain grooves and those tires going squirrelly .. |
No shimmy at 60 but I do get one when I first start moving. I'm guessing the infamous warped rotors or wheels need balanced. I should be getting new wheels this weekend so I'll see if it still doing it.
Ng |
Check your lugnut torque...When I did my springs and removed my wheels I noticed that the lugnuts were on barely above hand tight :confused:
Ng |
Smooth as silk from 0-100, so far. Soon to be 0-100+
