Socket size for lugnuts?
What size guys for the OEM lugnuts?
Goose |
3/4", thin walled is best.
I have the 17" polished I have to use a deep 3/4 socket, my reg socket isn't very deep and will only catch the top part of the lug nut cap. 19 mm will also work, there are only a few thousandth diff in the two
Originally Posted by an08HHR
(Post 256051)
I have the 17" polished I have to use a deep socket, my reg socket will only catch the top part of the lug nut cap
Thanks!!
Goose |
I have the 16" aluminum rims and had to use a deep socket also. My standard socket wouldn't fit all the way.
I have a 4-way wrench I use to take the lugs off and to snug them up, then I use my torque wrench with the deep socket. |
(Post 256051)
Originally Posted by pg318
(Post 256103)
I'd assume it's meant to be 19mm, since the threads are M12.
In other words, either the 19mm or 3/4 will work just fine...correct?
Goose |
Originally Posted by Goose
(Post 256184)
Goose |
