Sub mounting depth
Old 06-23-2017, 06:38 PM
Squiirl421's Avatar
Sub mounting depth
I was wondering if anyone knew what the mounting depth for the factory sub is?
Squiirl421 is offline
Old 06-23-2017, 07:43 PM
Depends on the sub,
But seriously I've never had mine apart
Oldblue is offline
Old 06-28-2017, 11:05 AM
PittKrewBowling's Avatar
Another curious question: LS models with the sub knock-out - is it simply pre-wired for plug & play or do you have to run wire to radio from scratch?
PittKrewBowling is offline
Old 06-28-2017, 12:06 PM
Technical Moderator
You would have to look. I doubt the wiring is there, but it might be.
donbrew is offline
Old 06-28-2017, 04:07 PM
skyline26's Avatar
if you want it to look factory, then you can only use a shallow sub.
Or you can put a box back there or build a custom box and fit it in the wheel well..which i was thinking of doing a while back.
regarding the wiring, mine didnt have any wiring back there
skyline26 is offline
Old 06-28-2017, 05:15 PM
livingfortomorrows's Avatar
I'm planning on doing this and making a tutorial, but I can't even get the time lately to wash her, much less install anything.
livingfortomorrows is offline
Old 06-29-2017, 07:31 AM
My LS has the Pioneer system with the sub, you must be thinking cars that didn't have the Pioneer system option
Oldblue is offline
Old 07-05-2017, 09:21 PM
07azhhr's Avatar
I cannot remember the exact dimensions but I found and old post of mine where I mentioned it being less than 4" deep.
07azhhr is offline
07azhhr
10-10-2012 02:27 AM
barfan1
01-24-2012 09:27 AM
retro-king
01-21-2011 06:34 AM
prod
01-09-2009 02:07 PM
h3reye51nroam
11-16-2007 05:18 PM
Quick Reply: Sub mounting depth
